I have a + copter and I have a problem with two motors cutting out on low throttle. When I start up and I give 50% throttle, all motors spins up and work correctly, flyable (on small props).
When I reduce throttle to less than 50%, motors north and south (1 and 4 I think) cuts out. I have to reduce throttle to zero, then up again past 50% before they spin again.
I thought it was the ESCs, but if I changes the plugs on the motor outputs on the board, the problem moves to the other motors. I've done the ESC throttle range etc. many times, with and without the board.
I've finished my quad a month ago, but I've been having this problem since and simply can't fly it.
I've got the HK 2.1 board, tried with default firmware and CptKuk 4.7, problem persists.
Is my board faulty?
Many thanks
Is my board faulty?
Many thanks
