If I were to use the wing from a FT scout or other plane on a fuselage of similar size and weight, would the CG I should aim for be in the same place or will the differences in fuselage and tail feathers need a new CG?
If the plane is approx the same size then the CG point will be the exact same. The only real difference is when using the wing on a canard as the lift is distributed across the foreplane and the main wing.
Assuming on a standard "tractor" design that the tail has no loading then the wing balance point.CG will be the same.
