Fbords
I've been looking at the videos on how to seal foam board with Minwax, and would like to do it to my FT3D and upcoming builds, but have a few questions I don't see answers to. Ideally, it seems to make more sense to keep the foam whole while applying (as in the FT video) to ensure i don't miss any spots including tight corners.
1) If we were to apply the minwax to full sheets, how easy do the pieces cut or pop out (if a pre cut kit)? Does the Minwax get in the grooves causing the pieces to stick together?
2) If the sheets have minwax applied how do you crease, bend, or fold the pieces without harming them? it seems to me the coating would harden the surface a bit.
3) Is it safe to assume that the finish is applied to the poster board pieces as well?
Thanks!
Thanks!
