Question :delta swappable
kingbee
Hi guys
Question: about delta swappable . i have 480 eflite brushless motor for a corsair .could i mount it to the delta swappable?or would it be to strong ? what would happen if i did try and fly it that way ?
earthsciteach
That is A LOT of motor for that little delta. What battery do you have? I'm betting the combo would be too heavy for the plane.
kingbee
Park 480 Brushless Outrunner Motor, 1020Kv
Product Specifications
Type: Brushless outrunner
Bearings or Bushings: One 4 x 9 x 4mm Bearing, and One 4 x 10 x 4mm Bearing
Wire Gauge: 16
Recommended Prop Range: 10x7 to 12x6
Voltage: 7.2 to 12
RPM/Volt (Kv): 1020
Resistance (Ri): .06 ohms
Idle Current (Io): 1.10A @ 8V
Continuous Current: 22A
Maximum Burst Current: 28A (15 sec)
Cells: 2–3S Li-Po
Speed Control: 25A to 40A brushless
Weight: 87 g (3.1 oz)
Overall Diameter: 35mm (1.40 in)
Shaft Diameter: 4mm (.16 in)
Overall Length: 33mm (1.30 in)
Needed to Complete
25A–40A brushless ESC
2S–3S Li-Po
10x7–12x6 propeller
OliverW
Wire Gauge: 16
Voltage: 7.2 to 12
RPM/Volt (Kv): 1020
Cells: 2–3S Li-Po
Needed to Complete
2S–3S Li-Po
10x7–12x6 propeller
Did you ever get it flying?
