So, I bind the Rx to the Tx. After all the beeps I can use the controls and throttle as normal. Then, when I power down, remove the bind plug, and power back up, Everything but the Throttle works.
Things I've tried:
1) rebinding (about 12 times)
2) setting throttle stick to 100% to calibrate ESC (does not work after bind, but did seem to work during bind. I'll make a vid of this if requested)
3) Bind, power down Rx only, then test
4) Bind, power down Rx and Tx, then test
5) Bind using the button, and the bind setting in the dx6 menu
In ALL cases: the throttle works when the bind process completes as seen in this video:
, but after power down / up, only the Throttle does not work.
Any ideas!!?! Thanks!
https://youtu.be/xE0CCYStEUM
Things I've tried:
