I am building a V-tail Hunter Quadcopter I used a Racerstar StarF4S 30A 4 in 1 ESC/Flight Controller upgraded to betaflight 3.2 and an Orange r617xl receiver. I bound the rx to my Devo 7E before the build and it bound fine. But now that the leads are soldered to the flight controller whenever I recycle power the receiver goes into bind mode. It seems to bind (for all of the good it does considering it resets each time I power it on) the light stops the fast flash and goes solid when I select bind on my transmitter. But the flight controller gets no signal. I did NOT use the betafligt CLI to bind the receiver and I ran a dump and verified that these functions are all set to off or 0. Additionally I thought it might be a poor solder job but with the signal and ground pads separated by that 5V+ I don't believe it is simple as the connection. Does anyone have any insight into what might cause this behavior. Could the flight controller be defective oddly when I check the flight controller for continuity between the signal and ground pads I don't get any. I don't know why my rx is going into bind.
