Radio reccommendations
ofiesens2
Professional noob
I am trying to figure out what radio system to use if I am to get into all the FT scratch build airplanes. I received the FT Flyer, Nutball, and Delta Speed Build Kits for Christmas, along with a Spektrum rx so I think I will be staying with the Spektrum and OrangeRx brands. I already have a DX4e from my Super Cub RTF, but for all I know you cannot center servos with that thing. Should I use the DX4e or buy a different radio?
bicyclemonkey
Flying Derp
Sticking with Spektrum, a decent upgrade from your DX4e would be the DX6i. The DX6i will do pretty much anything you need it to. It was my first radio I got almost four years ago when I got into the hobby and I'm still using it to this day (even on gas powered models).
rcspaceflight
creator of virtual planes
#3
Unless you are using the wrong terminology, you can center a servo with any Tx. All centering a servo really is, is to plug in the servo to the Rx, power up your system, and then screw the servo arm onto the servo.
I say keep what you got for now. It's cheaper that way.
rcspaceflight
#4
Although, I don't think you could use your Tx for the Delta. That requires some mixing that I don't think your Tx can do. But if you really want to go cheap, they do make a device that mixes so your Tx doesn't have to.
ofiesens2
Professional noob
#5
Ok, thanks to you both. Rcspaceflight, I'm a beginner and I really don't know what "centering servos" means. The official FliteTest guys have a video on connecting electronics, and they use a specific method involving digital trims with a DX5e.
If you could help me interpret what they mean by "verify", that would be awesome.
ofiesens2
Professional noob
#6
There actually is a switch for delta wing mixing on the DX4e next to the reversing switches, and there is the same thing on the DX5e.
rcspaceflight
#8
I don't know how the trims work on the Dx4. But Josh is just saying that you want to make sure that your trims are centered when you are centering the servo. You don't want the trim to be all the way to the left because if you end up hooking everything up a little off, you can't trim it to the left because the trim is already over all the way. I think Josh was moving the trim all the way in one direction, then the other, and then back to center to make sure that the trim is centered. Its just so the electronics force the servo to the center position so when you add the servo arm, the servo arm is on correctly.
Bolvon72
I concur with the others, the DX4e will fly all the swappables and is capable enough until you have built up the scratchbuilding and flying knowledge to decide that you need more, like expo and mixing. The DX5e is not at all different from the DX4e save the extra channel and i still grab it to quickly bind to a new build just to run it up real quick.
pgerts
Old age member
Centering the servos is done easy the way rcspaceflight says.
Trim is another thing and it can be done mechanically if you make a U or V on the pushrod end. Tighten or widen a little to trim your rudder surfaces.
An Orange or Spetrum TX has an advantage over 9 T9 or any other radio with a module - MODEL MATCH.
I was out flying with my friends on Xmas Eve. My friend has an expensive 1000$ Futaba and a "fancy" quad with "everything".
Starting with the wrong model setting almost cost him a lot more than the cost of an Orange T6 or Spektrum DX6i transmitter.
Unless you do not want to fly other than DT Foamies in the future - save for a good transmitter - a 6 channel is good for storing 10 different plane setups. a DX7 or 8 will store 20 or 30 model setups.
Craftydan
Hostage Taker of Quads
Orange transmitters do not have model match.
Completely agree, though, its an exceptionally valuable feature - if you haven't picked that model's setup, it simply won't bind.
While all *real* programmable spektrum radios have this, it's not entirely unique - I know at least the frsky taranis has it as well (called Receiver Lock), as might any TX running openTx.
