Radiomaster Pocket ELRS binding issues to R88 Receiver
Grant Ross
I run an afterschool RC club and have made the mistake in buying 3 Radiomaster Pocket CC2500 and one Pocket ELRS. I have the Power pack A, from flight test, with numerous R88 receivers. I cannot seem to bind the singe ELRS pocket to the R88 Receiver as I did with the three CC2500. I am using FRSKY D8 protocol, updated the firmware, tried both the internal and external RF, and changed the SD card. Is there something I am missing? Why cannot the ELRS version bind?
Any help would be greatly appreciated. I am having trouble finding any support on this specific issue.
best,
The R88 is NOT an ELRS receiver. You would need an external MultiProtocol module on the Pocket ELRS transmitter, or an ELRS receiver.
Something like this that I have on my Pocket ELRS transmitter.
Grant Ross
I knew there was something obvious. I tried to get the Radiomaster Pocket CC2500 from flite test and they only have the elrs version. Whoops. What is the cheapest ELRS receiver that would work with this pocket version? Thank you!
Grant Ross
I just got the same thing you have, the RM4in1 module from radio master. Thank you for all the insight. Bumbed I have to buy something else, but the kids will still get to do other cool stuff with the ELRS on this pocket.
best,
Will the FT pocket cc2500 bind with a Skyfly FS-iA6 receiver?
No, FlySky requires the Amiccom A7105 chip. The CC2500 does not support FlySky
AmiccomA7105FlySky
FlySky AFHDS2A
Hubsan
TreadHead98
The CC2500 chip only supports specific protocols like FrSky (ACCST V1/V2), Futaba S-FHSS, Hitec, Radiolink, and Graupner HoTT. At least as far as I know...
Supported CC2500 Protocols
    • FrSky: D8, D16 (ACCST v1 & v2) — Note: Does not support ACCESS, TD, or Twin.
    • Futaba: S-FHSS
    • Hitec: Optima, Maxima, and Minima
    • Corona: v1 and v2 DSSS/FHSS variants
    • RadioLink: FHSS systems (2.4GHz only; incompatible with 915MHz systems)
    • Graupner: HoTT
    • Redpine & Skyartec: Select micro/bind-and-fly variants [1, 2, 3, 4]
Key Limitations vs. Full 4-in-1 Modules
    • Missing Chips: A CC2500-only module lacks the NRF24L01, A7105, and CYRF6936 chips found in the full RadioMaster 4IN1 Module.
    • Unsupported Brands: You cannot bind to Spektrum (DSM2/DSMX), FlySky (AFHDS/AFHDS 2A), or most common low-cost toy/RTF protocols (like V761).
John M
I really don’t want to het into protocol stuff. Just want to know what works. I also had FT send an r88 which Josh used in one of his videos. Can you confirm that receiver will pair with the cc2500 Pocket?
TreadHead98
Yes. So first, that is with an R88v2 receiver, which supports the Frsky X (D16) frequency, though it can still be used with the Frsky D8. Both versions of the R88 support the D8 protocol, only the V2 supports X (D16) which has a stronger signal and failsafe support. The binding process for the X (D16) frequency is a bit more involved, but since Josh made that video, you shouldn't have any trouble.
Btw, I don't know if Josh mentions this, but if the transmitter is very close to the receiver, you may notice the control inputs are jerky. This is because the transmitter being so close floods the receiver with signal, and it will not be a problem during normal flight.
John M
Well I do have the V2version but could not find the D16 as a selection on the cc 2500. Where would I select that. Do you know if there is anyway to get voltage telemetry from the R88 receiver or a receiver that can with the cc2500. I find it disturbing the manual for the cc2500 states updates will continue to add compatibility but RadioMaster says that is not going to happen due to the limits of the chip used. Also a Photo of Flysky as a selection in the manual…
TreadHead98
Sorry, my instructions might not have been clear. The D16 protocol is the "Frsky X" protocol, they are the same when you select Frsky X for the "type" then select D16 as the "subtype". Stock, the R88 does not have voltage telemetry support, there are some mods that can enable it if you feel like soldering. Otherwise I think there are some older receivers with the ability, but still you will need some sort of seperate voltage sensor or voltage divider to plug into the receiver.
As for the manual, that is just a copy paste from the 4in1 manual, the CC2500 chip cannot support Flysky AFHDS protocols.
John M
Ok I have a sensor what receiver would work with the cc2500. If you don’t know it is ok to say so. The cut and paste is the whole issue. The $65 Flysky transmitter and receiver have a telemetry port, PMM serial port to the Aura5 lite and everything works. No shipping and 2 day delivery from Amazon, I I really thought the Flitetest gear from the store would be compatible…
