kilroy07
Let me start off by saying this was NOT my idea, I do not know where I saw the idea first, but it has become my favorite new skill with foamboard planes.
The "problem" is I have a laser cutter... (I know, I know... sucks to be me) anyway, my pieces come out with a bit of the foam shrunken back from where the heat from the laser cut it.
Not only is this unsightly and probably affects the flight charastics a bit (at least it's one more thing I can blame my crashes on) but it's dangerous as well... I've gotten some nasty paper cuts (sometimes two in parallel!)
So, I gave using a covering iron to clean up the edges a try... and let me tell you, it has changed everything...
You can take an edge that looks like this;
And turn it into an edge that looks like this!
I suggest you give it a try if you haven't before and really want to dress up (and strengthen*) your builds.
*Yup, I've found that not only are the edges much more resilient to dings, but the process makes the parts MUCH stiffer as well (especially good on tail/control surfaces!)
Here's a quick video on the process;
