Raising d/c rate
wassup guys, on one of my planes im using a 2200mah 3s 20c. My question is, if i up the d/c rate to 25c or 30c but still have the same specs 2200mah 3s, can that cause my motor/esc to run hotter? any help will be appreciated! thanks!
pgerts
Old age member
That depends a lot on your motor.
If your motor is pulling round 40 Amps today then the motor will probably be somewhat stronger during longer time from start.
Hi C-ratings are good when it is cold or when you want more power during the flight.
With a low C the battery voltage will drop almost directly from the start and you will feel lower power but the Hi C battery will keep the voltage up better until the battery is close to empty.
Your motor will not get any hotter if it is designed for the 3 cells.
