Duck
So my Mini Arrow finally had more then it could take and the wing ripped from off starting at the underwing bay and all the way along the fusalage. I was practicing low passes and I got a little too low.
Any suggestions on putting it back together? I love my Mini Arrow and would build it from scratch if I had to but it looks like I might be able to build a solid joint. My plan is to:
1) Remove the fuselage entirely
2) Glue the seam edge on with hot glue
3) Laminate both sides with packing tape
4) Reattach the fuselage as if I was building it new
Given the wear I have on the nose I might replace the fuselage entirely with a new one made from elmers foam board I can get locally. I've been wanting a little bit more space as I can't actually fit the power tap for my FPV transmitter and my battery monitor at the same time. I am terrible with timers so I really prefer to always have the battery monitor. The step I am most worried about is actually gluing the seam back together. Given the ragged break I am really doubting it will have any strength.
Thoughts?
Thoughts?
