Rames
Here's my first go at designing and building from scratch. First, I learned everything I'm doing here from either Flite Test or NerdNic videos and builds (and all the people who inspired them). Second, my plane choice is driven by the fact that Douglas Devastator does not receive much love in annals of aviation history. While the TBD was cutting edge technology when introduced in 1938, by the time of its disastrous performance at Midway it was hopelessly obsolete. I seek to honor the impossibly brave men who flew her; the pilots and gunners of Torpedo Squadrons 3, 6 & 8. 41 planes started the attack and only 6 made it back home. More later.
SPECS
WINGSPAN 43in
FUSE 27in
CHANNELS 4
MOTOR: - LazerToyz Beef: 2210/1280 Kv 8x4 prop
ESC: 20 AMP
BATTERY: - 2200 mah 3s
SERVOS: - 4 x 9g
BUILD DIFFICULTY: Intermediate
MATERIALS: DTFB
PLANS:
View attachment TBD PORT WING_SPAR.pdf
View attachment TBD FUSE_STAB.pdf
View attachment TBD AFT DECK.pdf
View attachment TBD COCKPIT_V2.pdf
View attachment TBD STARBOARD WING_DECK_WHEELS.pdf
View attachment TBD CANOPY.pdf
View attachment TBD FILLET.pdf
The design borrows heavily from the FT Spitfire. In fact, I use the exact same spar. The rest of the design is driven by the 3-view images I found on the web.
View attachment 33442 , View attachment 33441
The wing build started with an ill-fated shortcut. I tried removing the DTFB paper and min-waxing (water based) my full scale plans directly to the foam board. Hopeless warping ensued. It was probably for the best, because I ended up making 6 or 7 wings before finally getting all the cuts, bevels and hot glue correct.
wrinkled paper
yikes. zero chance of flying straight
After six or so different builds, I finally got it right. I used the exact same spar from the FT Spitfire
The fuse and stabs went much smoother.
I peeled the paper off the inside of the bottom plate to get a smooth curve
Standard FB PowerPod mount
Next is the turtle deck and cockpit. Once I know everything fits, I'll post the plans. I'll also fill in with some more comments. Enjoy!
SPECS
WINGSPAN 43in
FUSE 27in
CHANNELS 4
ESC: 20 AMP
SERVOS: - 4 x 9g
MATERIALS: DTFB
PLANS:
wrinkled paper
