WillL84
Saw this on Thingiverse and finally printed it out. I printed two actually, going to mount one to each wing of my Legacy V2. All parts printed with PLA. Might reprint in PETG if I have any problems with the parts.
Link: https://www.thingiverse.com/thing:3735108
My make: https://www.thingiverse.com/make:1015688
Now I didn't have any M3 bolts long enough so I ended up tapping the doors with an M4 tap and then drilling out the plate holes with a 4.2mm drill. I then installed an M4x12 from one side and an M4x16 from the other until they butted together and snugged them up. Also there's no holes in the servo mounting posts and my 9g servos were a tad small so I just hot glued them to the plates. Then I drilled a small hole in the front door arm for the servo wire. Finally I drilled out the hole in the rear plate with a 2.5mm drill so the skewer would fit better. I used a dab of hot glue to glue the skewer and the small spring in place.
Short video of it in action:
