Help! rc pancake wing pre-design questions
badpilot27
so i might build something similar to a Vought v173 as a stol plane and im unsure what motor prop combo I should use.
I'm going to use 2 motors, run it on a 2200mah 3s battery and try to use large props to maximize the amount of prop wash over the wing.
I'm also unsure if I should use a cambered or symmetrical airfoil. I think a cambered airfoil will improve stol performance, but the real v173 used a symmetrical airfoil
alright i just ordered the motors, escs, and props for it
i got 2 a2208 1100kv motors, 1045 propellers, and 2 30a escs
again its gonna be run a single 2200mah 3s lipo
does that seem good?
Very Plausible. I used to have a quad with 4 of those motors and the same battery. Plane will be much easier on the pack.
badpilot27
@Mr Man any idea on what's going on here?
It may be that it can’t figure out how to make it with those guides. Maybe just do several lofts to get the right shape. (That’s what I normally do)
The guides also have to be constrained to the point on the sketch otherwise it won't work👍
It's a KFM wing profile, just a bunch of flat sheets glued together in various widths top and bottom, center aft being the longest. No lofting, no tapers, easey peasey, just basic math. Like 30% times max chord
Kfm style wing is built up using stepped sheets of foamboard no taper, no sanding, SOMEWHAT blunt LE (45 degrees on a table saw). Supposedly builds vortices at step ends that negate drag. A Kfm 3 is 3 layers thick at the LE, a KFM 6 would be 3 layers up, 3 layers down. There used to be an airfoil thing here but Google is your friend. Incredibly easy airfoil to make, just glue sheets together, shape LE on table saw. Figuring out step widths is the hardest part, but is totally non critical. Wing it makes is almost indestructible. DON'T make me take a picture of my flying wing and post it..
I don't think that's what he's going for, i think he's trying to make a more realistic model. I think, 👍👍
badpilot27
would a kfm airfoil be better at keeping flow attached to the upper wing surface than a clarck y type of airfoil?
