I am trying to see which would be the best option to power a 2300 kv motor powered by a 30 amp esc. Prop is 7x5. I have not had a great experience with lipos. Out of LiFePo4 and NiMh and others which is the best option to make a powerpack to power this plane. This is for a ft mini scout so a smaller battery size would be great. Would something like 123A battery work? Thank you! Also something that is hopefully not so reactive as lipos to fires!
If you are talking about a indoor plane using a motor like
you might get away making a battery pack with LiFePo4 and NiMh. But you'll quickly find that those chemistries will not permit the high-discharge rates required. I use LiFePo4 in a high discharge battery bank for my boat "house" bank. It is fully able to drive a 1800 W microwave, hot plate etc. HOWEVER in the case of high rate for LiFePO4 is
2C!
Even a small brushless motor like a A2212 can pull 20 Amps... from a 1500 mAh, that is 13C. LiFePo4 can't do that. NiMh can't even pull 1C. Even the ubiquitous LiIon 18650 is only good up about 10C in very special models made for vape dispensers. The normal ones don't do more than about 2C. Note in a typical top quality LiIon... it can only do 4.5 amps for short durations. That is ONLY 1.9C.
It believe the second best after LiPo is Lithium Titanate, but it is very expensive and it too can't handle anywhere near the 60C, 120C that you'll see marked on common everyday hobby LiPo.
