RC RADIO SCAM ?
tomlogan1
I really don't have a dog in this fight but what the hell... Most transmitters will be more than adequate as long as you have enough channels to grow. I started with a 6 channel radio because you only NEEDED 4 channels (Aileron, Elevator, Throttle & Rudder) and if you were really advanced, you used channel 5 for Landing Gear.
Then I found out about mixing and separate elevators and multiple motors.
Get all the channels you can afford in your radio and ensure that the radio/receiver combination can grow with you.
My original radio could handle 10 channels and 10 channel receivers were easy to get.
Then I needed a couple of more but didn't want to toss out all the earlier receivers. So I got a multi-protocol radio.
So stick with one that supports the most channels & receivers with large numbers of channels.
My 2 cents.
My 2 cents.
Yup, I;ve got the 10ch fly sky,
Zoom Master
My 2 cents.
True and thats what im doing ! Im getting a radio with more channel then I will ever need ! (probably)
Sometimes it's about having the right kind of channels too. A 6 position switch for flight modes can be handy. Sliders and/or knobs for mid-flight rate adjustments other than high/med/low, etc.... 2 and 3 position switches and buttons. Momentary button/switch....
Zoom Master
Pretty sure my radio has all of that.....I think ill look into it...
Current radio is absolute garbage.....and doesn't have a lot of features. I was talking about the radio im gonna get not the one I have.
A radio that has all that can't be too bad......:unsure:
True and im going for ELRS cause im gonna be soon building a long range fpv wing...
I agree with the others, I you are going to FPV, I highly recommend a FC & GPS. Return to home is a great feature to have when everything else fails. Where I live, it's an ocean of corn, very easy to get lost flying FPV & not know which way home is.
