Today we take a look at the Ready Made RC 5.8GHz FPV Quick Start Package.
Included you will find:
- RMRC-420N NTSC CCD Camera with built-in microphone
- ImmersionRC 5.8GHz 600mW Transmitter
- ImmersionRC 5.8GHz Uno Receiver
- RMRC 8" Monitor
- 1100mAh 3s Lipo for receiver and monitor with Y-Adapter and 2 Barrel Connector adapters
If you are also looking for a great beginner FPV platform, we recommend the FT Versa Wing. It is extremely durable and is built with only two sheets of foam!
David constructed a simple swappable FPV "pod" out of our FT Element Simple Firewall.
When starting out, it is usually a good idea to go with a monitor instead of goggles. If need be, it is much easier to look up from a monitor then remove goggles to find your plane.
To tower dive, or not to tower dive? That is the question. We say TO TOWER DIVE!
But tower diving comes with consequences. Here is just a bit of the damage.
RIP Mobius Action Cam 2013-2013. You were more than just a camera. You were a loyal and humble friend. We will never forget you.
So if you're new to FPV or just need a great setup check out Ready Made RC, and when you do, make sure to use the discount code FLITETEST10 for $10 off your order!
Thank you so much for watching! We truly couldn't get away with any of this stuff with out you.
