Good luck! Double check your rates, trim. and CG before you launch, be sure to be well away from trees, concrete, lakes and other plane eating terrain.
Add a 1mm or so thick shim to the leading edge of the TT wing, it adds incidence which makes it a little more floaty feeling by adding lower speed lift.
