relay to reverse a motor?
Fishbonez
Was not sure where to post this question so I guess right here. If I am the wrong spot please feel free to move it but,
Ok here is a question for all you electronic geniuses out there. I recently took my HZ Super Cub out on the water and one time it floated into the weeds and I had to out into the water to retrieve it. Was it a big deal? No but I was wondering if it were possible to put a relay or something similar in line between ESC and the motor to a switch that would allow the motor to go in reverse to push the Cub out of the weeds? Just curious if any one has done it or am I as loony tunes as the next guy and should stop drinking so much coffee. :cool: Eager to read any and all responses
Thanks
pgerts
Old age member
I think that there are boat controllers with reverse ;-)
-- As you are "boating" and not flying in the weeds.
Foam Addict
Squirrel member
I'm certain you could do that.
When I still worked on Model Railroads, I used relays quite often for various functions, and they are very versatile.
FlyingMonkey
Bought Another Trailer
Admin
It would probably be as easy to put in a variable pitched prop, and manage that in your throttle mixes, or through a switch.
Ak Flyer
Fly the wings off
A reversable esc would do it, a variable pitch prop would do it, a pair of relays could do it but you need another channel to make it work so it won't be cheap.
earthsciteach
Here's your solution, Bonez: Get a labrador retriever puppy and train it to retrieve your SC. Name the pup, SWD - Swimming with Disaster. :D
tramsgar
I agree with pgerts, a boat or "waterproof" car ESC will do well. I use a fishing rod for my seaplane, although I've had better success with full scale boats or stripping down to get it myself.
Ak Flyer
Fly the wings off
Here's my solution...
I knew that Tyco Terrain Twister would come in handy some day.
squishy
Pirate ParkFlyer
That is the most innovative and useful way to use a useless item I have seen..simple too...
xuzme720
Dedicated foam bender
Weren't those made in the early 90's? I haven't seen one of those in like ...forever!
randall_l
I'd go for the variable pitch prop myself. Just my opinion here--it would probably be more efficient than reversing a fixed prop. Fixed props tend to make more noise than thrust when reversed.
As for the relay, I gave it a try. I found that (with the various HobbyKing/Turnigy ESCs I have), the motor stops working when I reversed it. I had to dis/re connect the battery to get it to work again.
Now that I think about it, a variable pitch prop is a good idea for my upcoming swappable Dehavilland DHC-2 Beaver. Thanks for the idea FlyingMonkey.
Cheers!
Randall
Fishbonez
Much love for the green machine. That is just great and probably the best way to do it I have seem yet LOL.
Teach I did try to get my dog to jump out and go get it but she looked at me like I was some crazed lunatic who got their plane stuck in the weeds LOL
After some research it can be done using an ESC from a car and or micro switch between ESC and motor and a servo but seemed like an expensive experiment that may cause motors to burn up etc so I think I will just hold off and maybe look into buying that green machine
