mmeyer
The frame arrived today so i could finally get to work on the mini quad. I'm pretty happy with the frame overall especially considering i only paid $22 for it. There are a few small issues with the frame as you'd expect from such a cheap frame but nothing too bad. Here are a few pictures of the frame partially assembled.
One of the odd things i soon discovered was that the frame comes with 8 x 3mm bolts with corresponding lock nuts but there are 3 holes per boom so i would have thought 12 should be included. Then again that might just be because its a cheap frame and i don't think it will be an issue in the long run.
The second and slightly more annoying issue i came across was the fact that this frame doesn't have holes to suit the smaller flight controllers. This means i will have to mount it with tape or drill out some holes to suit the smaller FC's.
Other than those two minor things i cant complain at all about the frame. The arms seem to be 4mm G10 and the rest is 1.5mm which for a quad this size and weight should be plenty strong enough to accommodate for my less than professional flying.
I ended up getting the 12A EMAX banggood esc's and i was just curious about the solder jobs on three of them. As hopefully you can see in the picture there are a few solder bridges. Is this an issue and should i try and fix it or does it not matter?
I just now have to work out the power distribution system and i think i am going to try and make it as clean as possible by using only the wires that are already on the motors and esc's and building it like this:
All the esc wires are 20AWG so they should be able to handle the current. I dont think i should need any more wire than whats already on the esc's and motors so hopefully i can get away with that. Is that a good idea?
I will keep posting more updates as this build progresses and i am beyond keen to get it in the air.
