Montiey,
I think the OP was looking for something the other way around . . . the airframe is smashed and electronics are to be resalvaged.
Hoss,
Welcome to the forum!
Hmmm . . . that's a toughy. that frame is VERY light, and the way the controls work you'll nose up/down with throttle might make mounting the electronics critical. hmmm . . . pusher too, which might work against keeping balance . . .
Might I suggest something like this:
anything like this should do. build it to stock and fly it and if she flies ok, find the balance point front to back and mark it. Then when you go to mount the electronics, mount the motors so the props are just behind the wing. once everything is mounted, add just enough weight as far forward on the nose as you can, to move that balance point back to the place you've marked.
**BE PREPARED to build several** there's a good chance it will fly horid the first time you launch it. It's all a part of the process. Look at what it did, and go back and adjust/repair and fly again -- if you're not sure how to adjust it, we can help you. a pic or two and a description of what it did can go a long way.
Oh, and it will break . . . but if you build it, you can repair it, and when it gets so bad you can't repair it, you can build another
