GunHog
Thanks for the help in advance. OK, lill new to the sport.
Building Versa Wing (pusher)
Motor is an EMAX 2010/11 from LazerToys (The Beef electric kit for FT Versa)
The Stator (magnets) case rotates with the shaft.
The Armature with the plug wires is stationary and has the mount. The shaft extends out of the Armature case spinning with the stator.
Q: Is this the wrong motor? Do I need a stationary stator?
Q: Can the shaft be reversed to extend out the Stator casing"
I have no way to use the supplied motor mount as the plug wire will come over the rotating stator. The motor would have to be mounted behind the firewall with the shaft transitioning through the fire wall.
Confused,
Confused,
