I am winding up all my other threads except the one titled "wing loading ****" and continuing here.
This is my latest layout for the FW 190. I have "de-uglified" it a bit:
Removed the front upper gun deck;
updated the canopy design;
flattened out the joggle in the rear fuselage;
smooth the motor cowl;
fattened the fuselage overhead profile a bit.
Wing , tail, tailplane up in dimensions. Wing layout taken from Severesky Guardsman (later Republic) USA, shortened a bit. - This is a semi-elliptical layout.
Wing area is up 18 %, mean chord up 29%, wing shortened 8% This is based on getting a 7 inch diameter cowl and 50 inch wingspan.
Overall the scale is 1:7.65 of the full size aircraft.
I have also shortened the front undercarriage to suit a 14 inch prop, and make it usable for landing and takeoff on grass. wheels are 3.5 inch diameter. The original aircraft is really raked, and a guaranteed tripover on grass.
The original plane has an 11.3 ft prop, on a small aircraft.
The 14 inch prop scales to 9 ft in diameter.
Wings are also raised a bit, thickened, and dihedral reduced. To be electric powered, 4 kg thrust, 10,000 rpm, 0.9 N-m 1 kW -probably 6S, 60 amps?
Weight aim is 1.5 to 1.6 kgs - 3.5 lbs.
It should have low enough wing loading to do away with the flaps.
loading is 15.4 oz/sq ft, ignoring the area contribution of the fuselage. -Is this the usual way of working it out?
The fuselage is not a very good lifting body, with super-low aspect ratio. The drag would be more than the lift.
I also found that the Mustang was originally built by Curtiss, later amalgamated with North American.
Also , there was a (possibly) radial variant of the P40 Hawk -though photos and plan drawings may be mislabelled-I will
do some more Google research.
This is where I got the nose length to canopy dimension.(this was a Lavochkin La 5 -Russian.-a similar-looking plane).
I propose to keep the main gear retract. Possibly I could pinch the tailwheel retract off a 1.2 m mustang model-
about the right size? - you can buy the separately from Banggood.
Their retracts are also much cheaper than the I-flite ones you get in NZ.
How do the gear doors normally get opened and closed?
I was working on a wire lever arrangement being pushed by the wheel, but that is
tricky, and likely to leave a gap.
Can you used staged actuators?
It has to open before the gear starts to move, and close after the gear has finished lifting?
Also, I want to conceal the rudder horn and the elevator horns.
I have heard of the kinked wire method for the elevators. That should work with a slot in the back of the elevator, to allow for the angle.
What wire thickness do you need to cover about 10 inches? I was thinking 2mm (80 thou)
Would this work, or is there a better way?
I could use a similar trick with the rudder, with a wire bent to 45 degrees, and a long slot to fit.
The rudder only needs to go 30 degrees each way. The wire needs to be twisted a bit more-over 90 degrees total.
Again, is there a better way to do this?
The undercarriage mod does make them look a bit stumpy, but more in line with larger planes like the Hawker Tempest.
What do you think?
I have removed most of the quirks that make it recognisable as a FW 190, and it looks more like a generic ww2 fighter, but more attractive than most.
This does not replace my current build, but I thought I would do a little planning for the next one!
ut
What do you think?
