rocket/prop plane
mr.sandypants
can you make a plane that takes off with a normal engine, then gets up to altitude with a rocket engine and then flies back with the prop engine
+ if you want a challenge make the plane from foam
PS: it would be cool if the plane had a twin boom tail
f91ddr
Master Tinkerer
I think they did this already, but I think it was more like a controlled rocket that a plane with a rocket.
mr.sandypants
I tried it with my p 38 lightning, i put the d class rocket in the cockpit pod thingy, it flied like a dream until i decided to put TWO f class rockets in it. It flew high but at the end of the climb i didnt have wings anymore. R.I.P p 38
mad_milchmann
ooooh thar wozld be nice... they could even try rocket powered fly-bys and see how fast it can get :)
first fly at normal cruise speed then activate the rocket - zoooooooom ;)
Stradawhovious
"That guy"
You would have to program a motor brake or use a folding prop. If not the prop would act as an air brake when the rocket was engaged.
Charlie123
Hey, I suggest you guys use small engines like mini engines to increase TWR and keep the plane intact due to the sudden acceleration.
I suggest using a highly areodynamic plane with wings that are angled back, one designed for high speed.
Tritium
Amateur Extra Class K5TWM
Video?
Thurmond
FAI-F1D
Free Flight Indoorist
Nope. Flutter can get even worse with swept wings if you don't stress them correctly.
All of the aforementioned questions on rockets come down to simple, common sense solutions. Several folks who fly rocket gliders competitively have used Drela's Apogee 36 as a baseline for a rocket powered setup. The only changes are to put a rocket pod above the wing in a location where the fuel burn will not cause a CG shift, and switch the tail to either a Y configuration (V tail with sub fin) or an inverted rudder and standard stab location. The Y tail setup allows the model to still be discus launched for trimming (you don't want to launch one of these rascals until you know it will go straight).
The easier solution to a survivable rocket glider is a swing wing setup. I've built a bunch of these for free flight, and the only failure I've had in a multitude of launches was the time the launch piston hit the models tail on launch and caused a real quick disintegration. Even then, the model was back in the air the next day.
It's breathtaking how high you can get on just a C engine. Using a launch piston, the altitude is good enough for 3+ minutes of glide. Aerotech makes special long burn D, E, and F engines for R/C gliders, and the Estes E's are excellent as well, if a bit heavy and sooty.
As a final note, here's an old R/C contest model that should lay some groundwork for how to make it work. And yes, build light. http://georgesrockets.com/AOL/GCGassaway/RC/Synchronicity/Synchronicity.htm
