Rookie Pilot from the Last Frontier
ModernWarfox
Hello pilots and builders,
My name is Riley, an amateur RC pilot and builder in Alaska. I have been flying since 2013 when I inherited an old Hobbyzone SuperCub. Since then I've spiced up the Cub and added a few more birds to the hangar (Dynam PBY and a few small EDF jets) but only recently have tried to build my own. I found Flite Test while browsing YouTube for tips on how to start the new plane.
As with all of my projects: Go big or go home. Using knowledge from both Flite Test and RCSuperPowers I decided to begin construction of a 28" Northrop YF-23. It is a magnificent plane but also appeared quite simple to assemble with foam board. The long, straight lines and relatively flat profile were easy to draw and cut; construction of the airframe was completed in just under 4 hours.
At the same time, I wanted to contrast the newer-gen design with a taste of the Golden Age: The Curtiss P-36 Hawk (A favorite of mine in the Free-to-Play air combat game War Thunder). Much more complex to build but i hope she'll be worth the effort.
I'll have to do some digging around the forums a bit more but eventually I would like to post the results of my experiments for critiquing.
See ya' in the skies!
- Warfox, out.
Jugsy
Welcome to the forums, your projects sound awesome! You'll find tons of help and inspiration here. Definitely post some pictures or video when you have them, we also like to see work in progress shots :)
If you'd like to join a few of us for a more casual chat too, there's an IRC channel that's slowly gaining popularity:
https://kiwiirc.com/client/irc.freenode.net/?#flitetest
Come and say Gday when you have the time!
