Help! Running a 90mm EDF motor on 6s with a 7x6 prop
Ryan O.
Out of Foam Board!
Now, the Help! prefix is for 2 reasons. 1: I don't know if this would work, and 2: I need help because I may have gone insane... I saw how fast David was able to get his spit going on 4s, so what if I were to take a motor from a 90mm EDF and slap a 7" prop on it and hope for the best? I think that if I were to run this on a FT BF-109 with clipped wings, a modified firewall, and metal gear servos I could get it going much faster than the Spit did. Maybe another 10-15 mph. The motor is an outrunner, and it is rated to 6s on a 90mm 12blade EDF, so I think it might be able to consistently use a 7" prop on 6s without getting too overheated. What do you think?
https://hobbyking.com/en_us/warhead...026&indexName=hbk_live_magento_en_us_products
Site Moderator
What do you think?
That’s too large of a prop, 90mm is about 3.5 inches. I’d start with a 4 inch prop and not a cheap one. I have had props explode from spinning too fast. Stay in front or behind the prop, don’t stand in line with it.
Start with a 10 second run, then stop and hold the motor & esc to check for heat. Warm is OK but if you can’t hold them, stop, that’s too hot. If it passes, try a 30 second run, then a 60 second run. If it passes the 60 run, try a larger prop.
I’ve got a 3000kv motor on 3S, that gets warm on a 5 inch prop. If the air temperature is above 95, I’ve got to back off the throttle or it will get hot.
leaded50
that motor is a 3545-1350KV motor, and if do a search on others similar in size, you find easy recommended props are approx
9 - 11 x6 . on 3s , Sooo,, 7x6 is even gonna be small .
