Join the wings
The wings are joined by gluing part WP2 (Dihedral Brace ) to both spars of each wing.
An accurate positioning of WP2 us very important.
In addition, parts R2A and R1A+R1B are glued at this stage.
Place WP2 next to the spars of one wing. The upper part of WP2 and the upper spar should be parallel.
There is a laser sign on WP2 marking its center. Use it to place it so that the wing will almost reach the center.
Place R2A.
Place R1A+R1B so that R1B will face the wing center as seen in the picture below:
The parts are ready to be joined. Do not forger the 1.5 spacers:
Since I was not able to use clamps, I have a set-up that uses a weight and many pins to create pressure on the bonded parts:
Now is the time to glue the second wing into place.
The procedure is similar.
Make sure the dihedral angle is accurate by placing WP2 accurately and by putting something to raise the other wing.
Now is the time to verify that the wings are correctly joined.
Note that the rear part goes not touch.
However, the leading edges of the joined wing are on the same level so we are just fine.
