S-bus anywone?
pgerts
Old age member
Orange receivers come with S-bus.
Is there anyone who have tried it?
Is it only Futaba who sells S-bus servos and HUBs?
If i have understood S-bus - you are programming the servo to the channel and is not limited to the channels on the receiver.
Example:
You have 2 ailerons - both on the same channel - just hook them up to the bus on the same channel number. That is naturally limiting the functions to only aileron and not flap.
Gear - you can have as many servos as wished for the main, nose or tail wheels on the same channel. You will program the delay and speed direcly in the servo and not in the transmitter.
But - does anyone use it?
/Patrik
