telnar1236
As I was designing my 50mm EDF jet trainer, @FlyerInStyle pointed out that it resembled the Saab 105 quite a bit. The Saab is an amazing looking plane that also seems like it should translate very well to RC and also one that I had never even heard of much less seen modeled as an RC plane before which meant it immediately caught my interest.
My original thinking was to use twin 50mm fans and have a plane twice the size of my mini trainer jet, but at that point you end up with a plane that is getting larger than a practical park flyer size range and would require a paved runway for takeoff and landing, so instead I've opted to go with a single 64mm fan (since I had it sitting around anyways and have been trying to think of something to do with it). This size should still leave it possible to hand launch and belly land and keep the complexity more manageable. Currently, my thinking is to make it 4-5 channels with flaps optional, though the flaps might not end up happening.
This is what I have for CAD so far. It needs some additional details and some blending of some the corners to get everything closer to the real thing, but overall, the shape was surprisingly easy to achieve.
Because it's a lesser-known plane, the 3-views I could find to work from weren't particularly great and in the one I ended up using the top view didn't quite match the side view for a couple things. In addition, I couldn't find any section views of the fuselage which means the shape might be slightly off, but I think it's pretty close from what I can tell.
So far as size goes, it's pretty middle of the road for a 64mm design and is 1/12 scale to the real plane. Not substantially bigger than my 50mm jet trainer with a 35.5" length and a 34" wingspan (slightly larger than scale), it is, however, substantially chunkier which gives room for the larger power system. Weight will probably end up around 1.3 - 1.4 kg.
