PsyBorg
Wake up! Time to fly!
Hello gang. Recently I have started a Tips n Tricks series and I am getting good feed back so far. Several people have asked various questions about how to work with heavy gauge wire for battery connectors and such. I have also seen a lot of people doing questionably safe things when disposing of lipo batteries. I decided today, since I recently had a brand new battery kill a cell that I would use that to make a how to get rid of lipos video.
The first thing I do when I have a bad or damaged battery is to drain off any residual power to make the battery as inert and safe as possible. I simply use the 12 v light bulb from my smoke stopper to drain of as much as possible. I leave it sit connected a minimum of 24 hours outside in a safe place. On higher c rated batteries like this one I will let is rest a few hours then put it back on the bulb another 24 hours as they tend to regenerate power over time for quite a while which is why just throwing them away is a REALLY bad idea as they can still cause fires at that point.
Once that is done I check it with a multimeter and look for the battery to actually be taking a charge from the meter itself. At that point is where I will start the video. I hope it helps you guys as well as make our hobby a lot safer and less chance of causing more issues then we have over batteries. Above all PLEASE stop puncturing them to make them burn its just bad all around.
