Hello all. Been a while since i've last been here so i thought what better way to start off that begin a build log. Only just finished the scaling process based on some cross sections i've found online. I'll be building it from some bluecore foam i've got lying around and its wingspan probably wont exceed about 30 inches. I'll be using a single pusher motor setup mounted at the back of the plane which will probably be the stock bixler motor running a 6x4 prop. Will hopefully get some pictures up with some more detail as soon as soon as i get some work done! Questions and suggestions are more than welcome!
