In the last couple days I've made a little progress:
Vertical stabilizer is pretty much done. I'm still thinking about how I'm going to make the hole for the hinge pin because it needs to be as perfectly straight as possible. One wing is cut out and I'm hoping to get the other cut out today. I got my dihedral sorted out and everything is looking quite nice. I tried to show the PVC joint. I made the hole in the outer panels that accepts the center section spar a little oversize because I'm going to add fiberglass inside the hole to create a stronger tube than just foam. I'm going to try wrapping the PVC in plastic wrap to keep the epoxy from bonding the PVC to the fiberglass. We'll see how that works out.
I'm about to make a big order from aircraft spruce for fiberglass cloth and epoxy resin. I can't decide if I want a quart or two, or a gallon. Shipping for a gallon is ridiculous, and slightly less ridiculous for two quarts. The problem is I don't really know exactly how much I will need for the whole thing. I'm planning on buying 8 yards of 3.74oz cloth. I think that should be more than plenty, considering it is 60" wide. How many layers should I use? 1? 2? More? I think one layer would require about 8 yards and 1/2 gallon of resin according to the online calculator.
I tried using Poly Urethane instead of resin on a test part and I wasn't happy with the strength, so I'll just use that and talc to fill in the weave afterwards as was suggested here. I'm going to try mixing epoxy and balsa dust to fill some of the larger gaps in my wings and other parts.
My buddy is making a wood form on his lathe for me to make fiberglass cowls. I still have to rebuild the nose to make a fiberglass part. I have no idea why I chopped it off in the first place...
I bought some white beaded foam to try to skin it with. It is much cheaper than the pink stuff. I'm sure it will be plenty strong with the glass. I might make another update tonight, depending on how much I get done on my day off.
