Marcus Thörn 54" FFVS J-22
With FTFF over and the popularity of the SE5a build I've had many inquiries here and there about showing additional building techniques. At FTFF I had a built-up Funder and Lightning where I diverged from the "flat out" style and built up airfoiled wings and fuselage and made a great ship. It was fast and slow... it just did not survive a pilot error.:black_eyed: I need another speed demon in my hangar and completing this build fits all those things mentioned above.
The FFVS J-22 was a Swedish fighter designed by Bo Lundberg out of necessity for Sweden needing an advanced fighter designed and built in-house. An embargo was placed on aircraft purchasing due to the outbreak of WWII. I'll share some historical tidbits along the way but needless to say it was a tech marvel for the country whose limited resources came together to make a fantastic machine.
I started this build back in February, where I was out of town on a business trip. With nothing to do in a hotel room and a snow storm upon me I hunkered down to make the bones of the fuselage. Knowing I would again make this plane out of adams foam board I cut out the fuselage formers sans the extra material for supporting stringers. The plans are from Marcus Thörn over at RC Groups. No posting of plans folks. I paid for them. They are originally for 1:13.33 scale. I've enlarged them to about 1/6 or 1/7. I'll do the calculation later to get the exact scale. Its been so long I cannot remember off the top of my head.
At FTFF, here on the forum, and even on my youtube channel, I've been asked many many times to show how to do the foam sheeting technique. If anyone has ever done insert planking on balsa builds its along those lines but I'll outline the job here.
The main thing to consider before building is factoring in the thickness of the foam you will sheet with. Your formers will need to have that thickness removed. Here it was a happy accident that my foam thickness was that of the stringers after the plan was enlarged. I'm using white gorilla glue here. My glue of choice. It fills voids and adheres to the foam very well.
For the Fuselage there is an about of strength that you will need to counter torque. The majority of this strength will come from the final glass work. The other strength will come from the glue holding it all together. Another key point is to sheet in such a way as to prevent twisting of the frame. I employ a checker pattern build. I'll show what I mean. Chose one side to start with. I started on the top left side. I started at the front as the curves are gentler and curving the foam will be easier and add strength as I build. I'm going for one section at a time, only between two formers. Break for the next section and then again. On the top right side I stagger the sections sheeted again, but in the alternate way. I made the side and top longerons extrude past the formers so I would have more for the foam to glue to. Cut the foam super straight on one side. I use my aluminum ruler for this. Over size the piece and I use aluminum ducting tape all around for this. Super sticky and adheres even when there is a bit of foam dust on the surface. I taped the straight side to the side longeron after curling the foam sheet on the edge of the table. Then I carefully mark where the top of the sheet should be cut. I always cut it over-sized the first time. Then do a second cut for final fit. Its ok if the sides go past the formers. I prep several pieces of tape and apply glue sparingly... not gobs. I tape the piece in position and the fun part is that anywhere you do not want the glue to expand to... cover it with tape. Once the glue has cured cut off the overage on the sides along with the glue that has puffed out. Watch your fingers as thicker glue sections will create more cutting resistance and your razor blade may slip as you get to easier spots.
Rinse and repeat for each section. See pictures.
