I've been scratching my head for a while now trying to figure out how I should do the cowl so I had access to the motor, ESC, and nose gear. The plans call for the top of the cowl to be removable, but I didn't want the clean lines of the Navion cut up like that, plus that would make adding a retractable nose wheel difficult - assuming I go with a retract...
Instead, I made the bottom "chin" removable, and plan to make an internal structure to hold the motor and landing gear. The lower cowl will then simply attach around these pieces, and preserving as much as possible the clean lines.
First step was making some cuts. I didn't have a blade long enough to do it as well as I had hoped, but some balsa filler will hide the rough edges. This first pic is with a little filler added in to smooth things out before adding fiberglass. After the glass is done I'll remove and clean up the internal formers, but for now they're additional strength to keep everything aligned properly.
Test fitting of a motor I had for another plane getting some work shows me that I should have plenty of room. The nose is plenty thick and will need to be hogged out a bit. This should allow me to keep the prop and spinner close to the cowl easily. After this picture was taken I laid down some fiberglass on the inside of the nose planking. It needed a little extra support for final sanding of the exterior and it will help tie everything together for the eventual motor/gear mounts.
The chin is now covered with a very lightweight fiberglass and Z-Poxy finishing resin. I considered using water-based polyurethane but have concerns about it softening the balsa filler. It probably wouldn't be a problem, but I've used the Z-Poxy a little in the past and really like how well it works. With the finishing resin covering the balsa it really makes the balsa planking look nice, almost like an old wood-hulled ship. I could see doing some type of plane and just leaving it with this "natural" finish.
