Ok, so I am done with my Summer project with my kids. and am getting back onto this one. So I am moving onto wing design and construction.
So for the spar I will be using a single piece of thin MDF. Its fairly light, very rigid, and nothing fancy... not to mention I've plenty on my garage. Looking at the views I am basing this off of I notice a couple things.
1: There is taper to the wing in the front-view. This can give me basically 3 angles for the dihedral. One for the bottom, middle, and top. Since I will be inserting the spar from the bottom I will use that angle. From there I can trim the top to suit the thickness of the wing.
2: I will more than likely be using an airfoil at the tip that will be thicker than scale. This really is not a problem per se, however if the angle of the dihedral at the top is not close the "look" will not be right and therein lies a sacrifice to be made. So, I need to plug in the numbers for the tip rib. If I go with the scale airfoil then I will more than likely need to cut the outer wing panels with some washout. Its not really more complicated that way but it will not look right from the side angle. This angle is not nearly as noticeable so I'm more inclined to do that. How much washout? To be determined. Depends on my wing loading. Heavier and I like more... lighter and I need less. The idea is to prevent tip stalling.
3: With the location of the servoless retracts I will have to locate the spar rather far aft of the calculated CG. This concerns me due to the fact that the CG tends to be toward the thicker part of the airfoil and is inherently stronger. Also, I'm placing more weight toward the rear. Never a good thing. I typically like to use Carbon fiber arrow shafts but working with angled shafts has not been a pleasant experience for me in the past. Not to mention... I'm out of them. I only buy them on sale in the fall when bow season is in. At $3 a shaft at Walmart... its hard to beat and yes I've looked.
4: learning from mistakes in the past I wanted to double-check my angles. I dug up my other view and got that angle. After that I googled images and found a decent front-view. Results were: 1st view was 7 degrees, 2nd view was 6 degrees, 3rd view (photo) was 6 degrees. NEVER TRUST YOUR 3-VIEW!!!! We are going with 6 degrees dihedral.
