kacknor
Build another!
The popcycle sticks at right angles into the foam running chordwise are to keep the rear of the wing from folding down like in this picture. The ailerons are in line with the actual trailing edge of the wing, but the rear of the wing (darker red area) has bent under the line of the actual TE. Hopefully you can see what I mean, if not I will try to explain it better. Your Schoolgirl will probably be ok I just automatically do it when I build a wing so I don't have to worry about it later. If your wing starts bending here it won't sit flat on the wing saddle.
That wing folding problem has occurred on both of my Tiny Trainers and a Bushwacker. I now add longitudinal stinger support (Popsicle sticks) on the underside of the wing of any build using rubber bands.
JD
