Hi Smith!!
Oh, that looked like what I did 1st flight on a stryker yrs ago, then figured out flying wings have to reflex the elevons up about like 10-15 degrees, and this, is neutral.
My 1st thought was generally a THICK NACA 18 symmetrical airfoil all the way around the cylinder ( symm ... same on bottom as on top
This aircraft, it's just an artist's idea of a fictional "cool looking" aircraft; by no means really a good aeronautical design having any kind of built in stability, and its going to want to roll even in fwd flight like a pool cue rolls on a table, so what if the cue was heavy on the bottom and some force pulled it up from the lighter top end? You would want to be sure and get the flat bottom of the Clark facing down to get this right ( around from 10 to 2 o'clock position )
then it I thought, why not have a lifting foil on top to try and hold the top of the aircraft up.... see pic in other post
This is the lifting airfoil for the top:
This is the fat symmetrical foil for the bottom to grab the air:
I really think this will work, it just won't have the best flight capability. But it is a very interesting challenge! Yah I think you are right when saying maybe you put a larger prop in there .... one thing I just thought of tho is that a larger prop, while being more efficient will also produce more torque roll forces, it will want to rotate the aircraft, so maybe if your cylinder is about 12" you might put a smaller prop in there to spin at a hi rpm, maybe a gws 9x5 if this is light or if you have a larger motor and things get heavy, a 100gram 1400kv motor and an apc 9x6e prop
remember we often set the angle on our firewalls with the motors to offset this problem with 3 degrees right and 2 or 3 degrees down
see on that 11.1 volt prop test on Cobra motor, apc 9x6e ( that's the prop Nerdnic used/tested the Suppo 1400kv motor with ) produced about 65oz of thrust ... I compared similar motors with the 9x6 prop to guess at what thrust you could get from the Suppo and Suppos often have 100kv higher that what is listed... if it spins a 9x6 with ease, good. A large prop will want to roll the craft over and a smaller prop ... less roll tendency
also with this roll tendency ---- prop choice not just the size: I think a thinner lighter prop might produce less torque force, like maybe a thin gws 9x5dd or some other thin light 9x6 or 9x7 like a graupner thin electric series 9x6 or 9x7, being inside a duct, you probably won't break many props, they won't be exposed anywhere
with this shape/ aircraft planform, you don't really have much of anything at all to counter for torque roll, maybe setting the thrust angle in the rear could help but just think of it ... all there is, the 3 stabs n ctrl surfaces in the back, the nose with the canards may not help much at all
I think to put an idea together short, simple, what if you scale this to make a cylinder 12 to 14" diameter, Clarks @ top, NACAs @ bottom, and use that Suppo 1400kv motor and some light thin electric 9x6 prop with a 3 cell battery, figuring you already have some 3s 2200s, maybe try apc 9x6e or 9x7 first since they are so common/ easy to find, later if you want to help the roll problem more if there is a hobby shop near, look at the thinner graupner props ( pricey, I know ). In your testing you may see so much roll tendency, it may just not work, but, I don't really know.
If we started out stacking it up as much in our favor as possible, it could with as much hi lift at the top, being carefull and sure to put all weight in the bottom as low as possible
Maybe you just try these ideas and whatever directions you have and see what happens, how it works
I have thought so much of this, after I finish the Savage Bobber, I kind of have a desire to play with this too.
Ohhhhhhhhhhhhhhh, where's the CG gonna beeeeeeeeeee
Now I think that cardboard chuck tester to figure out CG WITH the Clark airfoil at the top may be needed
But even without the foil, just a plain thin cylinder and the rest of the craft with its canards in front and rear stabs may be enough to help you find the right CG
Smith .... you can turn your pics right side up just in windows, right click and see the menu offers you options to rotate pictures
Leonard
Y'know... if you got a "BEEF" motor and gws 9x5ep prop layinaround you could just stick it on your cardboard tester along w/ radio n servos and see how this flies before investing w/ other materials
might want to test the cardboard chucker naked.... first, and get the CG figured out
"Well!..... I'ld like tuh see the Great Leslie try THAT one!"
Hey Smith
Do you have anything that you enjoy flying right now? Just thinking, if not, then you might want to build an FT Mustang, Spitfire, or Bushwacker, these would easily work with smaller cheaper motors you might already have in your collection, like that 1250kv 2217 "Beef" motor and a gws9x5dd w/ 3s batt
Feel like I should build a Spitfire or Mustang too, it's so little investment and looks great...been really slow to work with dtfb, plus I live n S Texas, it's hot and stuff made using hot glue may melt and I really like to always carry my plane n radio in my truck in case I want to fly. Nothing on my stryker will melt, it's foam & tape.
I have a stryker made fm the plane white foam blank and 1800kv motor w/ 6x4prop, but, I'm tired of stryker flying wings... not having the flight site in front of home depot may be the thing, it was on the top of a hill, I liked how it flew there... now they have a tire store on that nice grassy strip! On a 3s2200 I would get about 25min flights casual, floating around and chasing an occasional covy of birds
Did you/yall see on Youtube: Flite Test Spitfire flight and review -- Tjrosenberry
Looks real nice, has that mystique the quieter brushless electrics have that use 8x4 or 9x5 prop, warbird paint scheme
https://www.youtube.com/watch?v=sDKAVogLi7A
https://www.youtube.com/watch?v=gs0KE__lsL0
I like that cool blue overcast day he took the video on
See End Of The Road RCs Mustang and Fokker D7 biplane
https://www.youtube.com/watch?v=ZYg9v0VWOD8
Something you might want to do is get a Paint Shop program that works good for modifying or drawing pictures, I make these up as stat/spec/proj review sheets, everything at a glance on one pg, what it looks like, how big, WS, AUW, Pwr Sys details, who made it. TJ has a 4 video series on how he made his Fokker
These are great idea sheets, you make up or collect a bunch, and when ever you want to build a plane, browse thru these as well as other stuff
Found those motor n prop test sheets are quite handy, I know my Cobra 2820/10/1170kv will give me 57.5oz thrust w/ an apc10x6e on a 3s lipo, know your pwr system to have an idea of what your build weight could be, this is the motor I will use on the Savage Bobber which should come in at about 2#--- thrust=3.5#, planning on some good 3d hover capability
Haven't put these motors to the test flying them yet, BUT, everything about their look, feel, heft, size of shaft, choice for good quality noodle wire, all makes me think they are some of the best motors available aside from the really expensive top shelf stuff made in Germany
This one in particular just looks perfect for a lot of 2 to 3.5# models with its rpm range on 3s either apc 10x6 or 10x7e or one of those really cool looking black Master Airscrew 10x6x3 three blade props ...
For its size n kv, the Io is 1.6Amps, pretty efficient, but, you should look at something similar in Scorpion motors, their hi efficiency is interesting.
This Scorpion looks great for driving an apc 12x6e on 4s for almost 100oz thrust 6.25# of thrust, but, I did not miss it, $125
When I get back to work I might get this and some 4s bats for bigger plane projects
See Nerdnics Mustang thread, he likes the Tacon Bigfoot 10, I think that might be a real good choice for a motor too
Might get the Tacon motor @ MotionRC.com
Look at that P-39 video Nerdnic has on this page
http://forum.flitetest.com/showthread.php?9193-FT-Mustang-Build-Log&p=232589#post232589
Well maybe your planning fpv or something w/ versa wing?
