Scratch Built Balsa F-104
telnar1236
And now the fuselage is filled and sanded and the nosecone attached.
TooJung2Die
That looks really nice. I know you've got it all figured out but to me it doesn't look capable of subsonic flight. :oops: :LOL:
telnar1236
That looks really nice. I know you've got it all figured out but to me it doesn't look capable of subsonic flight. :oops::LOL:
Thanks. You're telling me. Every time I look at it I feel like I need to check back over the math again just to make sure it will get off the ground.
telnar1236
More progress, with the all-moving horizontal stabilizer now installed, but also some issues. The pull-pull system for the ailerons, which worked fine prior to being covered, decided to start jamming under load, so I've decided to replace it with a rigidly linked bell-crank system which should be more reliable while still fitting into the very thin wingtips. One of the cheap retract units for the main gear also decided to die on me. Originally, I thought one of the lines to the ailerons might have cut the retract's wire, but on inspection, it was a totally unrelated issue. Fortunately, after needing to completely dismantle V2 due to the EDF unit failing, I put more thought into access to all the electronic components for V3, so it's only a few hours of work, and more an annoyance than a serious issue, but it does mean I definitely won't get to maiden this weekend and probably pushes the timeline back to the end of the month since I expect to be pretty busy with other things for a bit.
telnar1236
After starting at a new job at the beginning of May, I had much less time to work on building the F-104, so I gave it to a friend who finished it. He performed the maiden flight this past weekend, and according to him it flies great! Apparently it is terrifying to land, and the wingtips are so low to the ground that they break off if you run off runway, but otherwise it is straight forward to fly and has fairly gentle if fast stall characteristics. He has some minor repairs to make, but I'll post pictures and maybe video next time I see him at the field and can get them.
