So with everything looking so nicely I thought it was time to do the maiden. Ah yes, the maiden, well let's say that wasn't as pretty. Technically I suppose you could call it a flight since it did leave contact with the ground. But the nose shot right up and looped over all in about a second's time. I decided to cut power and reconfigure the CG solution. I am looking at either increasing the nose weight or I have another thought. What if I vectored the thrust slightly downward?
To shift CG farther forward I will have to either add dead weight to the forward area or lighten up my tail which would mean notching the motor area farther up. But I want to try this thrust idea first if I can without beating up the airframe too badly.
Also, the hinges I'm using snapped on the starboard elevon, both of two hinges. So I will either replace them (I have plenty) with more or I will go back to a tape hinge which has been fairly reliable.
By the way, if you're wondering if I'm wearing a whitish yarmulke on my head the answer is, no.
I never noticed that there until now. My body has been giving me all kinds of surprises ever since rounding 40.
