Servo full range, EdgeTX/ELRS
joortiz22
For some reason I cannot get my 270 deg servo to go past 90 deg.
I believe it's because ERLS NORMALLY send PWM signals between 988 mu - 2012 mu
on my radiolink trainsmitter I just ext the out put and it works fine.
ERLS on the other hand won't let me and when I try it doesn't work.
I have found something called "ELRS pwm switch modes" these include
Hybrid
Wide
Full Res 8ch
Full Res 16ch
Rate/2
Full Res
12ch Mixed
Does anyone know how to use them to widen the output to get full range?
https://www.expresslrs.org/software/switch-config/
Link to servo I use
I will have to play with it again, but I am guessing you have already set your outputs to +-150 for each channel you are trying to use 270.
My radio shows 732us - 2268us after extending the min/max from 100 to 150
I also have E.limits enabled....
What Receiver are you using? There may be settings on the web config page for it. Busy getting packed for Flite Fest but if I come across my ER5 between now and then I'll plug some servos in and do some testing.
