To convince yourself the servo is actually fine just slacken off the rod retaining screw so the rod does
not move with the servo. I bet the servo will sound perfectly alright indicating that the linkage is too stiff and over loading the servo.
In a full size light plane if no one is holding the stick the elevator will "flop" to its bottom stop just under it own weight! That is how free moving the hinges and linkage are.
Virtually impossible to achieve in a small model but it should be the target for all control set ups. You cannot afford to waste the power of a servo. Save it for moving the control surface against the moving air.
