Aero_Knight
So the custom build I have is for an F-117 I am calling the FliteHawk. The way it is built, allows for an upper and lower control surface on the wings. To keep it simple I could just make it a 2 moving surfaces that is mixed for elevon control with just 2 9g servos. The TX has built in options for it like most TX. However, I would like to make it more interesting by adding spoileron functions similar to a flying wing because the design I did is essentially a stupidly short wing pretending to be a delta. I think I absolutely need 4 servos for this to work but I am not sure how to set up the mixing and coupling properly without a micro-controller providing the control algorithms.
Normally the servos on each wing would operate opposite of each other when used only as ailerons. Once elevator coupling is introduced they would provide the proper pitch deflection at the same time as roll control (Shown in the image below). Easily done by using a 2 channel setup with the TX option I have. For rudder control, spoiler/air braking is needed with the servos controlling the top surface and bottom surfaces opposing each other while providing the appropriate roll and pitch control. I don't think I can manipulate the 2 extra servos in that manner with the TX...or can I? I have never manually created a custom mix setup on my TX so it is new to me. I feel like I may require use of my arduino LOL
My Transmitter: Futaba T6EXP 6-Channel (Modded to support FrSky 2.4Ghz TX)
