setting up sprektrum in betaflight
razed
So disconnect the satellite from the receiver cut the orange grey and black wires and solder them directly to the wires you've noted?
Where does the receiver connect to? I just wanna make sure i do it right.
razed
I see what you have done... that is wrong...
here is the manual I have found....
https://files.banggood.com/2016/07/HGLRC F4 V5PRO Manual.pdf
According to the manual using ONLY a spectrum satellite receiver you want to use the top three wiree per the manual as follows:
Top wire to light grey
2nd wire down to Orange/red wire
3rd wire down to Black wire of the satellite.
IF that does not work take the light grey wire and put it to TX3. This is on the bottom of the pic 3rd wire to the right...
Hopefully the picture works
Thank you for the help!! That did it. I didn't enev need to order another receiver I had a satellite connected to another spektrum. Works great have in the air now. Thanks again guys I really appreciate it. It's been a challenge for me.
