Hi everyone,
I'm almost finished building a Mini Guinea Pig and am in the middle of getting the electronics set up. Just wanting to double check a theory with the brains trust here though before I potentially blow my receiver up:
I've decided to not go with differential thrust for the moment as I'm a noob. If I connect my ESC signal wires up through a Y-harness, that should be ok to plug straight into the receiver shouldn't it as the two BECs are effectively in parallel?
Thanks in advance for your insights!
