Swedishclouds
Hi guys!
I am about to start bilding my first tricopter, the Bat bone Tri!
What I understand from reading on many forums the experience comes from trial and error. For it is indeed a jungle with all components and what to consider for each individual component. I would like to share with you my setup so you are welcome comment on the various components..
Frame;
http://shop.flitetest.com/multirotors/bat-bone-tri-370-kit/
Engines;
http://www.hobbyking.com/hobbyking/store/__6247__hexTronik_DT750_Brushless_Outrunner_750kv.html
Great motor for the money, as I understand it?
ESC;
http://www.hobbyking.com/hobbyking/...ar_20_Amp_Multi_rotor_Brushless_ESC_2_4S.html
Recommended, really dont now anything about ESC..
Props;
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22450&aff=655899
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22451&aff=655899
Saw that it was someone else who asked the question regarding battery capacity what it is that limiting the size. Guess there's a limit how big vs the total weight(MTOW) on the Tri? But am I unrealistic if I try to squeeze in
3000mAh?
http://www.hobbyking.com/hobbyking/store/__10299__Turnigy_3000mAh_4S_40C_Lipo_Pack.html
or 5000mAh?
http://www.hobbyking.com/hobbyking/store/__10096__Turnigy_5000mAh_4S_35C_Lipo_Pack.html
Can also mention that the consensus is that this will be my test and knowledge platform to then mount the GoPro and FPV equipment and APM in a not so far future ...
Kind regards!
Frame;
Engines;
ESC;
Props;
3000mAh?
or 5000mAh?
Kind regards!
