Ham_Sammiches
My only issue with it is that it doesn't have much power. If you can plan ahead and have batteries ready when you want to fly you should be fine. Those larger 2200mAh packs take a while to charge and I don't like baby sitting the charger while it charges one pack after another. As mentioned, I parallel charge multiple packs at once to avoid that, but this charger doesn't really have the power to charge a couple packs at the 1C rate. I can still slow-charge them which isn't bad, and it's kind of cool seeing 6 batteries all charging at the same time.
What are you using for a power supply to run the charger? Those chargers need a good 12VDC source.
What do I need to charge multiple batteries at once? I have been using a car battery but I will get a wall plugin 12v source
