MrClean
The first link is the module/rx pack that they sell. It is a little more specific in that it's the High voltage module for use with lipo power and high voltage servos. If you just have standard gear you can buy cheaper receivers. Note, the module is the same for the transmitter it's only the voltage handling capabilities of the rx that is different. That RX will work with normal, 4-5 cell nicad/nimh packs too. You can buy all the rest of your receivers in low voltage configurations if you want.
This is the standard voltage pack. http://www.hobbyking.com/hobbyking/store/__14355__FrSky_DF_2_4Ghz_Combo_Pack_for_JR_w_Module_RX.html
This receiver, probably now a plus rx, automatically gives flight pack voltage telemetry, but you'd have to buy the display to see it unless you get into the 9xr and hack it for telemetry. I THINK they have that worked out over at Openrc forums, but check there first. Reading telemetry and not reading telemetry is a flick of the switch on the output module before power up.
