Not to oversimplify.....Thanks, She still need a bit more work though, I'm trying to work out a tip stall issue that occurs at low speeds.
It's already got some undercamber, and I want decent speed out of this design so I want to keep the excess drag to a minimum.Not to oversimplify.....
But maybe a little more undercamber on the Wingtips?
That's alright we don't start off as Einstein.Yeah, undercamber doesn't do a lot for speed...
I'm definitely no expert, sadly that was my only idea.
It's possible, CG location can have an effect on how the plane stalls, which is another thing I was going to mess around with.First of all, I love this plane! I am on my second version due to trying to fly inverted too low without sufficient experience... but how else am I going to learn, right?
Could the tip stalls be related to CG? I have my CG a bit forward of the markings on the plans, at about 40-45mm from LE, and I can´t say that I've had any trouble with tip stalls.
I will try to provoke the plane a little next time a fly and see what happens.
Just to let you know Grifflyer, I downloaded and printed off your plans and upon quick inspection I found a problem... there is nothing for me to complain about lol! Beautiful job bro. I can't wait to build this and put my own little spins on it. I checked out your maiden on it fighting hurricane force winds. Looks like a solid build and flyer. Thx for the contribution to the community and keep it shiny side up.After seeing how many people have looked for a Mighty Mini sized FT Storch, Bushwacker, or a UMX Timber clone. I decided to take on a quick challenge to make a plane. I've got the basic design done and flying very well, but there are other things I want to try out, and I don't have the parts to test those ideas. So I'm releasing this as a Beta design until all variations have been tested. The design flies really good without any bad tendencies. It can be built with one and a half sheets of foam. As seen from the video she'll fly quite stably even in heavy wind.
I'm horrible with names so I simply titled the plane exactly what it is until I can get a better name. Please post or PM me an idea for a name if you have one.
:UPDATE: I'm going to title the plane ShrubSmacker Thanks to @SquirrelTail
I also incorporated removable landing gear into the design, I currently have it held in by friction and haven't seen any signs of it trying to come loose.
Here's the Maiden Video, it was pretty windy, so much so that the plane blew over as I was trying to take off the first time, and gave me some trouble trying to take off the second time.
Plans: ShrubSmacker Plans V1.0.2
Note: When you fold over the wing, the spar will be blocked by the servos this is by design, simply cut out a small area out of the spar where the servo touched the spar.
I want to test this design with a wing using flaps and ailerons and possibly slats, but I don't have enough servos. If you would like to try building the plane setup that way please PM or post asking for the plans.
I would also like to try building this really light by removing all internal paper and then power it off of the FT A pack with a 2s battery. If you build the plane that way please post or PM me your progress so I can finalize the design.
Thanks!!!Just to let you know Grifflyer, I downloaded and printed off your plans and upon quick inspection I found a problem... there is nothing for me to complain about lol! Beautiful job bro. I can't wait to build this and put my own little spins on it. I checked out your maiden on it fighting hurricane force winds. Looks like a solid build and flyer. Thx for the contribution to the community and keep it shiny side up.
Ooh those look cool, I'm going to try 3d printing some of those.This plane is definitely on my short list of planes to build. I have the Bush Whacker but think I'll build this one first. I'll be adding my vortex generators to it. I know they've helped my timber out a lot.
https://www.thingiverse.com/thing:3349698
