Ok, time for a new plan. Originally the goal was to burn a gallon of gas before mounting the engine in the Cub, but at that rate it'll be Christmas before that can happen! It took at least 20 minutes of running just to go through maybe 3 ounces of gas with the test stand set up in the garage. The new plan is to get the fuselage ready and mount the engine once it's good to go. With the other Cub, the engine ran smoother and with less overall vibration once mounted in the plane. I assume it's because the airframe just doesn't amplify the vibration of a gas motor like a metal sawhorse and plywood. Hopefully that's the case with this engine as well.
For the break-in procedure, I'm running the engine for around 7 minutes at a time, varying the throttle from idle up to about 5,000 RPM for a few seconds, then back to idle. Throttle response has been very crisp so far and it holds a steady speed. After the short run time I let it cool down for around 10 minutes and then repeat the process. As it gets more run-time the break-in will include some wide-open-throttle runs. There are tons of different ways to break the engine in, but this method makes sense to me.
