Simple cub motor mounting
basslord1124
99% of the time I mount the motor to the firewall.. I very rarely use the X mount. Use the X mount to check which holes to use. Take your drill and enlarge a hole if need be. I'm guessing you are using the pre-drilled FT firewalls. Not all of them fit perfectly and may require some adjustment. Also, you can get by using only 2 of the screws.
BATTLEAXE
You gotta find two holes that are across from each other. two holes in the same corner won't work for obvious reasons lol
BATTLEAXE
I think the mounting is standardized so you have adaptability. sometime reaming the holes with a slightly larger drill bit works
